Question about Jwin Televison & Video
Yes I have a JWIN JD-VD 135 When I plug in no power no LED light. What part number on circuit board do I replace.I have a multi tester and soldering gun
Posted by Steve Setterlund on
Jim Goldsmith
  • 2,005 Answers
The fuse marked F-1 or, F-2
Posted on Jan 26, 2016
1helpful
Samsung TV no picture from any sources.
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Can you give me a number (e.g. C101) and spec for this capacitor?
Power LED light indication flashes?Yes,u want to fix it,there are no one or any specific capacitors to be replaced.The power supply board is the board,where the power a/c cord plug into it.Must check the whole power supply board,looking for dying and about to be dead capacitors.These capacitors are alway bulges or puffing up on it tops are the problems and the causes.These capacitors are dying,a must to be replaced.But if u plan to be replacing dying capacitors?Tools,u must have.A soldering iron,a desoldering pump or a roll of a desoldering braids,a roll of solders also a basic understanding of electronic and soldering is a must.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Does not read the dvd disc: NO DISC MODEL jWIN JD-VD 135
could be a dirty lens. otherwise it may need professional repair. i'm assuming you have tried other discs and they did not work also?
1helpful
2answers
I NEED THE REGION FREE CODE FOR JWIN JD-VD-141. THANKS.
With the DVD tray open, press 9735 on remote. A menu will pop up, arrow down to Region, then arrow right to highlight the desired region (0 for all). Press Select, then arrow down to Exit Setup and Select again.
Problems with Jwin Electronics JD-VD138
I just found this answer from another contributor.
Turn the power on
Close the drawer
Press 9735
Select Region 0
Exit Setup
You now have a multi zone DVD
2answers
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Blinking power light
I got the same problem too.
No Power
Hi Rusty,
Open the cover , there must be a blown fuse, replace with another fuse of same value. If still not working take to service centre. This is a case of SMPS power supply failure.
Please vote for me if this is helpful.
1helpful
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Televison & Video Logo
Top Jwin Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
