Question about Daiwa DF100A Giant Heavy Action Spinning Reel DF100A Giant Heavy Action Spinning Reel
Parts schematic big roller system
Posted by Douglas Townsend on
Jason
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Here is the link to a partial tear down done by Alan Tani: http://alantani.com/index.php?topic=5444.0
and here is a schematic:
http://schematics.mikesreelrepair.com/albums/daiwa/Daiwa_DF_100A.pdf
Posted on Jan 26, 2016
Jim Goldsmith
  • 2,005 Answers
Http://www.daiwaweb.com/us/service/manuals/index.html
Testimonial: "thanks guys schematic not to clear but got it done.mahalo doug."
Schematic daiwa df-100 big roller system
Hopefully this is the right one...here is the link
http://schematics.mikesreelrepair.com/albums/daiwa/Daiwa_DF100.pdf
Jan 26, 2016 | Fishing
How do I remove adhesive from rollers?
I have had this issue before when the laminating sheets were put in incorrectly (open side inserted as opposed to closed side inserted). Unfortunately, the manufacturer said that the machine is not repairable, and I had to replace it.
Oct 16, 2013 | Gbc HeatSeal Ultima 65 Laminating System
What is a grid foam roller?
The grid foam roller is like the foam roller but it has different foam shapes and densities which provide a more targeted trigger point feel. It's not too big so it's also easy to transport.
Sep 10, 2012 | Exercise & Fitness
My i900d will not feed paper , the paper will not enter machine.
Is the feed roller turning? You can look in the front of the printer at the big roller. Try to print and watch the roller. If it isn't turning prepare to buy another printer.
Oct 21, 2010 | Canon I900D InkJet Photo Printer
Haven't used it in years - XD5250 - it still works great - however the paper is loose - any way of tightening it up?
thats in the platen(the big roller) just check the small (feed roller) roller at the back of the type guide, or (the paper finger) in the big roller connected to type guide 3inch on the left 3inch on the right thats the part to tighten your paper
Aug 11, 2010 | Smith Corona Office Equipment & Supplies
Paper no longer picks up and feeds
If u look in at the back there is a big big Grey roller the a can clean and in the front there is a big Black roller that u can clean!Good Luck!
Mar 17, 2010 | Canon FAXPHONE L80 Laser
My hp lazer jet 1600 is making big black horozonal
Measure your marks and replace whatever is indicated by this chart.
Measurement Component
24.7 mm (0.97 inch) Developer sleeve
26.7 mm (1.05 inches) Charge roller
32.9 mm (1.3 inches) RS roller
37.7 mm (1.48 inches) Transfer roller
54.5 mm (2.15 inches) ETB rollers
56.6 mm (2.22 inches) Fuser sleeve
62.8 mm (2.47 inches) Pressure roller
75.4 mm (2.97 inches) OPC
Nov 09, 2009 | Office Equipment & Supplies
Brother IntelliFAX 4100 pickup roller
Need more info. Do you need help in replacing the roller? If so, it is a big job. You have to completely remove the doc feed asm and all covers to get to the roller shaft asm. Best to let a tech do it for you.
Have you tried cleaning it with some roller cleaner. Try a little bit of Goof-Off cleaner on a cotton rag.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Konica minolta magicolour 2530dl
open side door and there is a transfer roller / one big black roller on the cover/ try reinstall it, maybe its not installed correctly
May 14, 2008 | Konica Minolta magicolor 2300DL Laser...
Daiwa DF100A Giant Heavy Action Spinning Reel DF100A Giant Heavy Action Spinning Reel Logo
1,015 people viewed this question
Top Daiwa Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Daiwa Fishing Expert? Answer questions, earn points and help others
