It's actually a bunch of colored lines right next to each other so from a distance it looks like one line about an inch wide. It is always there, on all inputs, and it overlaps everything including menus. If I twist the TV the line changes slightly but it always stays in the same spot. I disconnected the ribbon cable that goes to the T-con board on the same side as the vertical lines. The screen went white when the ribbon cable was disconnected but I could still (faintly) see the line. I did not disconnect the other two cables that go to the t-con. What do you think is causing this? T-con board? Cracked LCD?
I hate to give you bad news but I believe this will be a panel issue and it's not going to be fixable. You can try a different tcon board but I don't think it will help
Search Results
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
How to fix / repair vertical lines on half of LCD tv screen ...
? 5:23
https://www.youtube.com/watch?v=8P_i-JIsrYA
Jan 27, 2012 - Uploaded by chipotletv
It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
how to fix led tv vertical lines on screen 55 ... - YouTube
? 9:47
https://www.youtube.com/watch?v=zE0eqB4Ppjw
Nov 11, 2012 - Uploaded by LUFERQUINT
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
