Question about Rival Crock Pots & Slow Cookers
I have a rival crock pot with corning ware insert model 3753 Recipes for slow cooker say loe or high but control is only in degrees. manual does it explain what temperature for slow suggestions?
Posted by debklopick on
exswiss
    Champion:
  • 287 Answers
Slow will be the lowest of the temps.
Posted on May 02, 2016
5 Related Answers
Anonymous
SOURCE: repalcement handles for Rival slow cooker crock pot model scu600
My black handle broke off, too. I went to the hobby store and got a wood ball not too big and drilled a hole in it the same diameter as the screw that held in the original handle. Voila, I now have a wood ball knob handle on my crock pot lid. You just install it and cscrew it on just like you do a new knob on a kitchen cabinet.
Posted on Apr 07, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Need a replacement lid for crock pot
http://www.crock-pot.com/Index.aspx go to this link and order your lid. enjoy.
Posted on May 19, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: insert of a slow cooker over a gas flame
Stoneware by it's nature isn't designed for use over an open flame, as the flame can cause concentrated "hot spots" which could damage (crack) the crockery insert.
I've used mine to reheat mac & cheese I've made using the crock pot, but then again, my Hamiliton Beach crock pot stated the insert was oven safe to 475 degrees.
As far as using in an oven, most crock pot inserts can withstand oven temperatures, but refer to the owner's manual and instructions that came with your particular appliance to see what they reccomend in that regard.
Hope you find this Very Helpful and best regards!
Posted on Aug 27, 2009
Testimonial: "thank you so much i didn't risk it as i love my crock pot use it all the time and didn't want it cracked!!"
Anonymous
SOURCE: Insert for the BB100 Rival BBQ Crock Pot Meat Cooker
I had the exact same thing. I got it about 1.5 years ago and just now am opening it only to find the ceramic inside is broken. I am going to try to call the crock pot service center tomorrow. Let me know if you found a solution that might help me! Thanks!
Posted on Sep 20, 2010
mpunzirudu
mpunzirudu
  • 41 Answers
SOURCE: how do I clean the metal container for my crock pot slow cooker?
mild detergent, do not submerse in water
Posted on Aug 20, 2012
Can i bake a dessert with no liquid
I found this PDF copy of Rival Crock Pot manual/recipe book that is the best, before Rival pared it down to maybe 10 recipes. It helped me out, because I lost mine and needed recipe for corned beef and cabagge. http://www.megaheart.com/pdf/crockpot-cookbook.pdf
Dec 01, 2013 | Rival SCV601 6-Quart Slow Cooker
Stoneware replacement crockpot
You might check at a "Corning Ware" store to see if they have a round lid that would work. Best of luck
Sep 26, 2013 | Rival 3050 Casserole 5-Quart
I have a 6 qt. Corningwear crock pot, model no. SC-5044 120VAC 34W. I dropped the glass cover on a tile floor and it broke into many small pieces. Is it possible to replace the glass cover, and if...
I need a new crock for my corning ware slow cooker model#SC-5044. I have been redirected to link after link. I just wanna pay for a crock and have it arrive at my door. Could it be that easy or should I have to buy a whole new slow cooker??
Oct 01, 2010 | Rival 38651-C 6-Quart
My Rival Crock Pot seems to cook a lot faster than it should. When the receipe calls for it to be on low, I put it in low but it seems to cook the food too quickly. What am I doing wrong?
Probably, nothing. About 6 years ago the standards on these were changed, to increase low to 200 degrees instead of 180, high to 300. Things that took 6 hours can now take 4. If you are using older recipes, or recipes perfected in older pots, they will always overcook. You can check this by putting water in, covering, and checking with an instant read thermometer after 1 hour. If it is 200, there is nothing wrong with you or the pot.
Nov 25, 2009 | Rival Crock Pots & Slow Cookers
Insert of a slow cooker over a gas flame
Aug 27, 2009 | Rival 38601 Smart Pot 6-Quart
Need a manual or recipes for roaster
I have an Owner's Guide for a Rival 22 qt. Roaster Oven, model# RO230-C saved as a PDF file if you want it.
Nov 09, 2008 | Crock Pots & Slow Cookers
Lost label on the front of my rival 37401 slow cooker
The Rival product site has not retained the instruction manual for this model which is a 4 quart model. Nor have I located the manual elsewhere. However, I have located a generic slow cooker manual for 4 to 7 quart models. And, if you google the model number rival and images, you see a picture of the model. The print is terribly small in the images but I have discerned that to the far left is the OFF, each of the three other marks represents an increase in temperature, low, medium, high. If the dial does not "click" you can at least approximate where to turn it from the image. The user feedback reviews would seem to suggest not leaving it on high for prolonged periods and to be careful with the lid least you break it. Here are a few links which may be helpful:
https://www.crock-pot.com/on/demandware.static/-/Sites-crock-pot-Library/default/dw17097c78/documents/instruction-manuals/4-7-Qt-Manual-Slow-Cookers-IB.pdf
Rival Crock Pot Parts
Nov 18, 2017 | Rival 33511 5-Quart
Replacement handle
I'M TRYING TO FIND THE HEAT CONTROL KNOB FOR THE WHITE CORNING WARE SLOW COOKER
Oct 28, 2007 | Rival 33511 5-Quart
Crock Pots & Slow Cookers Logo
239 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Mike
dannydoesita
Paul Carew
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
