Question about Razor E300 Scooter
How do I get my Razor scooter to run? It has new batteries and smokes at fuse box when reset is pushed
Posted by Michele Ann Welsch on
Lawrence Oravetz
  • Razor Master
  • 10,543 Answers
If the batteries are connected correctly (red to +, black to -) then the motor is trashed
Posted on Jan 25, 2016
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
Where is the reset button at on the razor bella scotter?
there isn't one, but there are fuses by the battery that can be replaced
Jun 12, 2012 | Razor USA Razor Pocket Mod Electric...
Razor e300 needs to be continually reset
Sorry it is really important to get your scooter put together and charged right away or it will get ruined Need new batteries
Nov 12, 2011 | Razor E300 Scooter
Scooter has new batteries and still barely runs up slight hills its the E 200 scooter
On the Razor E200 check the chain is fully tightened & lubricated & you will be amazed what incorrect tyre pressures will do (36psi) to the power of the scooter.
Jun 17, 2011 | Razor E100 Electric Scooter
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Jan 11, 2011 | Razor E300s Electric Scooter With Seat
How can you fix a e100 razor electronic scooter when it wont move?
Fitted New on and off switch also new reset button. Battery ok but will not start
Nov 14, 2010 | Razor E100 Electric Scooter
E20 razor rocket electric scooter will not charge and someone said you need to insert a fuse but it doesnt tell you were or how. i have only purchased this as a christmas present for my daughter but it...
If it is a fuse problem then try looking for a fuse box in the controller or charger. If not then take it back, unless stated in the manual that you need to enter a fuse before it will charge, the scooter should charge right out the box.
Another thing you might want to try is to turn the scooter off before charging.
Dec 28, 2009 | Razor E200/300 Electric Scooter Battery
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Razor E300 Scooter Logo
128 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
Dennis Key
Dennis Key
Are you a Razor Toy Expert? Answer questions, earn points and help others
