Question about Electrolux EW1000i Front Load Washer
How do I clean tub on Electrolux front load washing machine
Posted by ronald coleman on
5 Related Answers
FitzOriginal
Chris Hall
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Posted on Mar 12, 2009
Anonymous
SOURCE: I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
Posted on Dec 13, 2009
Anonymous
SOURCE: i lost my manual for
Here's a link to the manual:
http://www.electroluxappliances.com/Files/Documents/Use%20and%20Care/EIFLW55H_uc_EN.pdf
Posted on Aug 23, 2010
Anonymous
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
Why is my eiflw55hiwo electrolux front load washer not properly draining the water at the end of the wash cycle?
hmm sounds like as if any water sensors arent working as they should inside the washing machine's basket or the diagnostic board isnt getting the right info from its sensors in the washing machine's wash tub
Aug 22, 2017 | Electrolux Washing Machines
How to clean Electrolux front loader washing machine
Thank you for your inquiry, Charles!
From my understanding you need to clean your Electrolux front load washer. The best way to clean out your washer is to use a hot water cycle and a cup of bleach. I would also recommend cleaning the front gasket using a water and bleach solution. You can visit a home store to see if they offer any type of washing machine cleaner as well. I hope this information is helpful to you. -Matt
Jun 06, 2015 | Electrolux Washing Machines
Electrolux front load washer leaking bleach onto floor
may be u use diff soap? check ur soap if is for front load or top load?
if soap is correct but still leak its means the hose or tub is have crack and coz of leaking.
call the technician for your safety and not to waste money.
Oct 31, 2013 | Electrolux EWFLW65HIW Front Load Washer...
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
My front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Aug 03, 2011 | Electrolux Washing Machines
I have an Electrolux Aqualux EW1200 i washing machine which is around 6 years old. The problem is that the drum no longer turns during the wash cycle. Instead it makes a slight grinding and banging...
6 years old - probably the wash tub bearings gone. Does the wash tub lift up and down from the front? sure sign bearings have gone. Would you drive a car at 70mph if the wheels were loose and floppy?
Not really a viable repair due to cost, and throwing good money after bad sort of situation, especially if your machine has a sealed wash tub which doesn't come apart.(welded Tub).
Cost of parts in this case would equal cost of new machine. Also, suspension, motor and heater will all be worn too. That's about the life span of machines these days I'm afraid!
Dec 09, 2017 | Electrolux EW1200i Front Load Washer /...
Water was not draining from tub. Read to remove front panel and clean out the filter. How do you get front panel off without denting machine?
Electrolux in their wisdom seem to have discontinued the lower front access panel.To avoid removing the complete front panel You can try this: Remove the back-panel and try to remove the clamp which holds the Hose( coin trap, tub-to-pump) to the tub. If the clamp is a spring-type and You can't reach the end to decompress it You can tilt the washer to the right side(seen from the front) and reach it from underneath. It worked for me.
Mar 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EW1000i Front Load Washer Logo
Top Electrolux Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
