Question about Insignia - Flex 10.1" Tablet with 16GB Memory
I'm having trouble with my front facing camera. I've already factory reset my tablet. What do I do?
I was able to use my front facing camera 2 days ago.
How do you factory reset this tablet?
    1)Go into your settings> Backup & Reset
    2)Tap the factory data reset option and to through the reset of the steps to confirm the factory reset
Nov 21, 2015 | Brix 7" Phablet GSM Unlock PC Tablet 4GB...
How do i unlock my tablet if i forgot my password?
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
Jan 27, 2015 | Kocaso M9300 Google Android 4.2 capacitive...
After setting up my tablet, i turned it off till the next day. So i turned it on & it won't go pass the dancing face on the tv box
Sounds frozen to me ! try reset and if that does not work , remove battery for 5 minutes always helps because you are resetting to factory default. Unless you reset to default it will stay stuck on the dancing face.
Dec 20, 2014 | Tablets & eReaders
Does this tablet have a camera facing the back instead of front pictures always
No. Tablet PC's, like notebooks only have one camera above the screen facing the user.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 02, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Unlock craig tablet without gmail acount?
try starting it holding power button and volume up or down keys it should give you option to reset.let me know if you need more help.
Mar 31, 2014 | Craig Electronics 8" 4GB Android Tablet w/...
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
RCA tablet how do you reverse camera
how to reverse the camera soI will be able take picture without the camera facing front
Dec 04, 2013 | RCA Tablets & eReaders
Insignia - Flex 10.1" Tablet with 16GB Memory Logo
53 people viewed this question
Top Insignia Tablets & eReaders Experts
Harrie
matt
matt
Claudio Roque
Claudio Roque
Level 1 Expert
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
