Question about Russell Hobbs Blenders
Glass jug of blender is cracked - Russell Hobbs Blenders
Posted by Lynn Logie on
5 Related Answers
Jose Mederos
  • 109 Answers
SOURCE: Replacement glass jug?
I will buy the blade set from you? I will return....
Posted on Feb 22, 2008
Pranali
SOURCE: REPLACEMENT GLASS JUG FOR KF 1850M DELONGHI BLENDER
I want to replace plastic jug of my blender, It leaks
Posted on May 05, 2008
Anonymous
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Posted on Jan 21, 2009
Anonymous
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
Anonymous
SOURCE: Broken glass jug - Sunbeam blender PB7600
I have one, marlene 0409465707
Posted on Feb 27, 2010
Glass Jug replacement for National Blender
I have that exact same blender, and I'm missing the lid. Are you still interested in the jug?
May 14, 2014 | Sanyo 5 Piece Cord Free Collection...
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
Replacement glass jug kambrook blender KBL110
hi I am after a 1.5L glass jug for kambrook KBL110. any idea where I can get it. thanks
Sep 22, 2012 | Blenders
Aug 26, 2009 | Blenders
Blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Blenders Logo
310 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
