Question about Refrigerators
How does a side by side domestic fridge work - Refrigerators
Posted by Harold White on
L Pfaff
    Top Expert:
  • Refrigerators Master
  • 11,573 Answers
New side by side layout is fridge side by side upper 2/3, with lower 1/3 pull out freezer
Normally in modern frost free systems only the freezer has the evap, and the fridge thermostat operates a duct, allowing freezer air to blow into the fridge.
The compressor runs until the freezer is satified, the thermostat powering the compressor is only connected to the freezer. If the fridge requires cooling but not the freezer, there's plenty of freezer air to circulate into the fridge after the compressor has turned off. Eventually the cmpressor will start again when the freezer temp gets too high.
On twin evap models, the fridge fan motor cuts out when the fridge gets to it's setpoint, so no air circulation through the fridge evap, though liquid refrigerant flows through it to the freezer evap. Likewise, if the fridge needs cooling but not the freezer, then the compressor will start but the freezer fan motor will not run.
Old school cyclic defrost systems had the thermostat in the fridge, and the freezer kept running until the fridge coil was low enough to make the fridge cabinet down to temp.
Refrigerator Wikipedia the free encyclopedia
Posted on Jan 24, 2016
Domestic refrigerator RM 2652 got to camper fridge off on off switch -no indicator lite 110V good. two fuses in control box looked goodno meter bottom of freezer was still very cool next day?
The heater element may need to be replaced. Does the fridge work well on propane or 12 volts ? If it does then the element most likely is bad. If it doesn't then there is a plug in the cooling system. Sometimes taking the fridge out and laying it in it's sides and upside down can unplug the cooling unit. It's called tumbling. If you go through all that and it still won't cool correctly, the cooling unit needs to be changed.
1helpful
Where do i add freon on a frigidare frs6lr5eb3. it is not cold on either side. i can here the fan and the compressor running.
Hello, welcome to Fixya. Unfortunately one cannot simply "add freon" to your domestic fridge. Domestic fridges have what is known as a "sealed system" therefore it cannot be charged without opening up the system and rarely needs to be for that reason, hence being labeled "sealed system". If you truley believe it is a leak in the system and needs repair you would need to call in a licensed appliance repair-person to work on a sealed system, most states and provinces it is illegal to work on without a cfc recovery ticket. Thank you for visiting "fixya". Let me know if we can assist you any further. Good luck. macmarkus :)
2helpful
What is the coldest setting on an old zanussi fridge freezer 1 or 6
hi there......the coldest setting on your fridge is 6
the normal accepted working temperature of a domestic fridge is usually between 0 and 8 degrees........the numerals on your thermostat are not temerature settings ...but a guide to coldness setting....the actual temerature must be checked with a reliable thermometer...usually best done in the morning after the fridge has ran throiugh the night without the door being opened.....
regards Sir Galahad
1helpful
I have a GE GSS22JFMC refrigerator and its not cooling or freezeing. I unpluged it open the doors and let it sit overnight. Plug it back in and it worked fine for a week. Then it stop cooling again. what...
you have got a defrost control problem, you will need a fridge technician to come out, you might get away with an electrician if he know a bit about fixing domestic fridges. One of these could be faulty, def timer, def sensor or heater not working. Not recommended for you to play around with, cause you are dealing with high voltage in this area of the fridge unit, very dangerous- you might fried, unless you are a licensed sparky:-)
2answers
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
HavFreezer not staying coe a Refrigerator that humms and clicks.
Okay, normally the refrig tech would tell you where abouts the hole is. Well I would of at least told you where abouts it was. Normally on a domestic fridge when there is a hole that you can repair, does end up costing abit of money.
In all honesty it is a risk. If you got a quote of say 200-300 dollars and a new fridge is 1000-1500. Then you have a high chance of the fridge going bad after the repair and costing you another 200 dollars. But you still are 500 up. But you dont have a new fridge.
Sorry if that dosent make sense but what I am trying to say is that it is a risk of loosing money and still havnt not having a new fridge
Freezer will not work due to out side teperature being low
Sorry, not doable. Temp in garage below 50 degrees will cause problems with any domestic fridge or freezer. The soda machines you see outside actually have heaters in them so they can work in the winter. Hope this helps!
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
