Question about Kenmore HE2 Plus Front Load Washer
Is leaking but not from the hoses.
Seems like all the water is coming out of the bottom.
Posted by Kim Hart on
  • Anonymous Jan 27, 2017
    I've got the same problem. I found a tear in the rubber gasket (boot seal?) that goes between the drum and the door frame in front. The tear is at 6 o'clock so it leaks right out into the drawer below an d out onto the floor. Any advice on where to begin getting at it to remove/replace the gasket? I tried patching the tear with silicone and it worked for about a week -- then the vibration of the spin cycle tore it loose again. How tough is it to get that gasket out?
3 Related Answers
Anonymous
  • 1937 Answers
SOURCE: water leaks from the bottom when it is draining
Check the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of sub-components will come up.
Check the listings and diagram for the tub and locate any gaskets at the bottom of the tub that could be leaking.
Another document that you can look at is a Whirlpool parts list (for commercial top load washers but consumer models are basically the same) and look at the basket and tub assembly.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on Sep 22, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 25, 2010
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: water is leaking from underneath checked all hoses
Could be hoses Sump hose or Door boot seal seperates the inner and outer drum this may have hole in it...
Posted on Mar 31, 2010
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
I have a miele G646 dishwasher whihs has sprung a leak into the bottom tray. Have dried it up and reset float switch but the water seems to be coming from a pipe on the left hand side of the machine. i...
It sounds like the leak is coming from the water intake hose.
The water intake house is located at the bottom sump of the dishwasher. To get to it the dishwasher has to be taken out and put on its back and the floor plan needs to come off. The intake hose runs from the inlet valve under your sink and attaches to the sump with a metal keeper. Overtime the part of the hose where the keeper is cracks (Normal wear and tear). As I recall the intake hose runs approx. $129.99 from Miele direct. It comes with an inlet valve on the hose. there is no separate or substitute hose you can use.
Good luck
Sep 12, 2009 | Miele Incognito G858SCVi Built-in...
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How can I fix my Kenmore portable washer 100.49722990?
Most common cause for water leak
is around the water level sensor connection, a small hose from the tank bottom rear, to the control panel, if loose or removed it is a small constant leak. if loose snip 1/8 inch off the hose refit and pull a zip tie around it tight
if it were the drain hose or pump, it would usually be a very large leak that increases when the pump is running and floods the laundry
Jun 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Kenmore HE2 Plus Front Load Washer Logo
162 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
