Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
I appreciate your post, friend!
Based off what you are describing your Electrolux cooktop is flashing error code "8". Normally, an "8" error code stands for key sensor for cook place 3. This means you could have a problem with your center board or left board. I would recommend performing a reset on your cooktop which can be done by flipping off the household circuit breaker for ten minutes. If the issue remains I would consult with a professional technician for diagnosis and repair on the cooktop. I hope this helps to some degree. -Matt
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
