Bought a used electromagnetic crane that doesn't work. Need a wiring schematic to rewire the 165 electromagnetic crane for lionel train
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
SOURCE: i bought the set last year of holiday lionel
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
SOURCE: my lionel train won't run at all. What do I do?
bad connections, wires to/from the transformer, or maybe a real dirty track.
try spraying a very small amount of CRC [brand ) 226 it is better than any contact cleaner on the market. do not get it on the rubber traction wheels on the engine. If you do, wash off with alcohol using a cotton swab on the rubber band on the traction wheel.
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
