Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050WA
How to reset after it was turned off - Haier 5 cu. ft. / 142 liter Chest Freezer HCM050WA
Posted by theresa harrison on
Hi .my hoshizaki ice machine it till running but do not make ice . Can you tell me , what wrong with the machine ? Thank you
The machine, all in one, not indoor/outdoor split type, will make beeping sound when something is wrong and stops working until it is turned off and turned back on. Some times the machine needs to be reset with the power on, covers removed, reset button inside on electronic mother board.
The ice machine covers have instructions and information on beeping sounds.
Aug 27, 2017 | Hoshizaki Freezers
Touchscreen is unresponsive. Alarm light is on and will not reset. Can not make any selections from the screen
Turn the power off for a few minutes then reconnect and try and reset . if no response you will need a repair man.
Mar 13, 2015 | Samsung French Door Refrigerator
Will not turn back on 3 beeps
remove the screw(s) and slide the cover towards the front (the cover over the control board near the wash/ice switch.) with the machine on carefully locate the reset button on top of the circuit board and push to reset..
Mar 18, 2014 | Hoshizaki Freezer Commercial Ice Machines...
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
How do you reset a frigadaire freezer
Time for a new freezer. The lights are telling you power is on and temperature not being reached. No amount of resetting will alter this.
Apr 11, 2012 | Frigidaire Freezers
Temperature warning light keeps going off. Resets
hi brian 20 degrees is too warm for a freezer i think you may have a dirty condensor coil its usualy under the freezer or on the back also check and if it has a fan on the outside make shure its turning let me know what you find and you can e mail me at [email protected]
Jun 09, 2010 | Kenmore Freezers
No power while plugged
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Freezer not freezing
Hello jannette859,
huuum at your service
You said,
freezer was working fine had to unplug it due to evacuation, now it doesn't freeze, is there any reset buttons? i didn't turn the temp selector to the off position before unplugging
Try turning off the temp. switch off.
Then plug it in and turn the temp on!
this may reset it.
Repeat one more time and let me know ho it went!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Sep 15, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050WA Logo
205 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
