Question about HP PSC 1315 All-In-One InkJet Printer
Feeding paper too early
The printer is feeding the paper a bit too early and then it creates a paper jam before it begins to print. When I open the print cartidage access door, the paper does not roll out automatically as it usually does. When I open the back of the hp, the paper automatically comes out. What do I do?
Posted by Storm Tango on
  • DreMeer Dec 02, 2007
    I've the same problem; even when I press the on button to start the printer after inatializing ( with a lot of noise) the printer is feeding a half a page and stops with bliking lights.
Anonymous
    Novelist:
  • 208 Answers
Try doing a reset. When you plug in the machine as soon as the lights flash. Hold the power and copy buttons down and allow the printer to do a memore reset.
That may help.
Posted on Dec 04, 2007
  • Anonymous Dec 20, 2007
    There is a feed clutch that engages that is probably sticking. Driving all the time, not part time.
    There could also be a spring off causing some components to not engage.
Paper jam
Hi......................
How to Clear a Paper Jam on an HP Inkjet Printer?????
Paper jams are among the most common problem with HP inkjet printers. Follow these instructions to learn how to clear a paper jam so you can get back to work.
Instructions Things You'll Need
  • HP inkjet printer
    • 1 Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    • 2 Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
    • 3 Look for paper through the opened back panel. Remove any paper you find jammed.
    • 4 Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
    • 5 Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
    • 6 Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
    • 7 Close the front access panel. Make sure that it latches back into place.
    • 8 Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this will helpful to you...................
Good Luck.............
Sep 24, 2011 | HP DeskJet D1460 InkJet Printer
Have a paper jam I can't get to .
1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Oct 02, 2010 | HP Officejet 6310 All-In-One InkJet...
It has paper jam some times on the begining of trasfr belt sometimes middel of that and also it send two diffrent error messages 13.01 and 13.09?
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Apr 20, 2010 | HP LaserJet 5550 Printer
Says paper jammed but this is not true
just try this,
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
8. Step 8
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Keeps saying there is a jam in the paper feed, when you open the front door there is no jam, reclose it and it will print
1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
8. Step 8
Thanks.
Have a good day.
Mar 17, 2010 | HP LaserJet 2420 Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Paper feeds fine from the manual tray but the main tray (the bottom) I continuously get a paper jam. It begins to feed then jams. Anything I can do to fix this?
Dear,
No problem.I can solve your problem.There are printer has two paper feed system 1) manual feed2) on cassate.When you get a paper jam in cassate you clean paper clauth or cassate feed roller clean.Some times is missfed because it can not creat frashor in correct.Clean it then solve you problem.Or some of paper bit here.
Dec 09, 2009 | HP LaserJet 1320n Printer
Paper jam - can't clear error message
Hello Nj,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on your printer.
How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
Hope this helps.
Aug 08, 2009 | HP Office Equipment & Supplies
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
167 people viewed this question
Ekse
efs_perpends
efs_perpends
