Question about Thomas and Friends Toys
We have a Thomas and Friends Shipwreck rail set. In the mast part of the ship the string has come off one of the wheels. Need to know how to put this part back together. The part with the anchor.
Posted by morgan ggrooms on
  • Nick Weisenberger
    Nick Weisenberger Feb 15, 2016
    I'm not sure if this is 100% correct as when I opened the mast it was all a mess, but after experimenting with it for awhile I believe I've got it back together how it is supposed to be. Watch the video to see how I fix the shipwreck rail set.
Nick Weisenberger
    New Friend:
Posted on Feb 15, 2016
4 Related Answers
Anonymous
SOURCE: I need the instructions to
service.mattel.com. Instructions can be downloaded. Product ref: R9634
Posted on Jan 08, 2011
bamb00zle
Fred Skinner
  • 3 Answers
SOURCE: i need a manual for
http://service.mattel.com/instruction_sheets/R9634-0920.pdf
I believe this is the manual you are looking for, available to read online or download for free. Hope this helped.
Posted on May 03, 2011
Ironfist109
Iron
  • 3018 Answers
SOURCE: I need a instruction manual
Regards, Tony
Posted on May 08, 2011
Testimonial: "Thanks so much for the quick response."
How can I fix the pulley system on the Thomas and Friends Shipwreck rail set?
How can I fix the pulley system on the Thomas and Friends ...
www.fixya.com/support/t25901578-fix_pulley_system_thomas_friends
Oct 10, 2015 - We have a Thomas and Friends Shipwreck rail set. In the mast part of the ship the string has come off one of the wheels. Need to know how to ...
We have a Thomas and Friends Shipwreck rail set. In the ...
www.fixya.com/.../t26065033-thomas_friends_shipwreck_rail_set_in
6 days ago - Question about Thomas and Friends Dolls, Playsets & Toy Figures .... can I fix the pulley system on the Thomas and Friends Shipwreck rail set?
Fisher Price Thomas & Friends TrackMaster Shipwreck ...
www.soap.com > Holiday > Hot Toy List
Rating: 3.5 - ‎84 reviews - ‎$70.79
... return policy. Shop Fisher Price Thomas & Friends TrackMaster Shipwreck Rails Set at Soap.com. ... Second time the whole system of springs and pulleys blew apart.... In looking for a on line tutorial fix found out this is a reoccurring issue.
Thomas & Friends Trackmaster Shipwreck Rails: Amazon.co ...
www.amazon.co.uk/Thomas-Friends...Shipwreck-Rail...
Amazon.com, Inc.Thomas & Friends Trackmaster Shipwreck Rails: Amazon.co.uk: Toys & Games. ...
Oct 10, 2015 | Thomas and Friends Toys
Can't find where to put battery in Thomas round the track adventure set
pull the fake middle wheel down, squeeze the tabs out, insert battery (takes 1 AA battery)
Jun 10, 2013 | Tomy Thomas The Tank and Friends Track
Roller coaster mountain road and rail instructions
roller coaster mountain is one big piece with a small removable castle and removable flag. if you have all these, all you need is the various track. you can look up this set on trackmaster thomas wiki and it will give you a list of the pieces.
Feb 15, 2012 | Tomy Thomas The Tank and Friends Track
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
Jan 10, 2011 | Thomas and Friends Battery Operated Train...
Does anyone have information where you can get replacement rubber tires / wheel grips for Brio electric train engines? (wooden tracks) We have a few electric engines that can no longer climb the hills...
I dont know where you can get replacement tyres. But here is a fix for the problem:
Using tweezers then fingers, pull off the existing tyres.
Take ordinary sewing thread, and wrap it around the V in the wheels (where the tyre was), about 20 turns or so, keeping the ends inside the V.
Put the tyres back on.
The thread forces the tyres further out, making some tread from the rubber available above the level of the plastic wheel rims.
Nov 06, 2010 | Thomas and Friends Repair Garage Fits...
How to replace battery for Tomy Thomas engine, which has steam and sound, using blue plastic tracks? thanks
Take the screw out of the bottom front remove red plastic panel by lifting up on the front, this will allow you to lift front wheels up and to the rear, remove center wheels press the tabs on the left and right side in and remove the cab. One AA battery, reverse steps taken and begin playing.
Oct 18, 2009 | Tomy Thomas The Tank and Friends Track
Toys Logo
452 people viewed this question
Top Thomas and Friends Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Thomas and Friends Toy Expert? Answer questions, earn points and help others
