SOURCE: parrot evolution
There is a tiny reset on the back of the parrot. Use a paperclip to depress and reset the device. This should remove any pairings.
SOURCE: Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
SOURCE: how to pair with samsung tocca?
On your Tocca
Press menu
Bluetooth
Press the phone in the centre of the screen and it will search for other bluetooth devices
The other devices will appear when they are found
When your Parrot appears touch it and drag it into the centre
It will then connect and ask for pin
Enter the same pin on both devices and then your ready
If this doesnt help let please let me know and i will try to help you further
JonnieC
SOURCE: bought new van with parrot ck3100
You need to delete the existing paired devices from the setting in the parrot before it will allow new ones.
