Question about Konica Minolta Office Equipment & Supplies
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Claude Kayser
    Top Expert:
  • Konica Minolta Master
  • 9,098 Answers
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Posted on Jan 23, 2016
5 Related Answers
steven brickhouse
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Anonymous
  • 167 Answers
SOURCE: Konica Minolta Bizhub 350, for faxing on Windows Vista PC
Yes you need the Driver.
http://help.bt.konicaminolta.ca
You can find all the drivers and help you need there.
Posted on Aug 29, 2008
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: konica minolta bizhub 350 error code c5352
Cooling Fan fault. To clear open and closer the front door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Apr 04, 2010
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
angelo_an28080
ANGELO ANTONIO
SOURCE: konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Posted on Nov 29, 2013
Manual for bizhub c350?
throw it away we are having nothing but probles with ares the rollers don't pick up from the adf and we cannot figure out why
Jun 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta adf is not currently available
what model number of the copier
Dec 17, 2013 | Konica Minolta bizhub Office Equipment &...
Konika minolta bizhub 350. When I try to Copy There is a message: "Pleaser Reposition Original". What does it mean? How can I fix it? The paper is checked (size).
BEFORE YOU PUT THE CHECK ON THE GLASS, SELECT THE PAPER DRAWER YOU WANT TO COPY ONTO, THEN PLACE THE CHECK ON THE GLASS, THE COPIER DOES NOT KNOW THAT SIZE
Aug 28, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
BIZHUB 350 C1183 MALFUNCTION
Hi richard_hutc,
It would appear that you have an issue with the finisher/sorter on the side of the machine.
Specifically, C-1183 means the elevator motor hasn't ascended or descended correctly.
Open and close the finisher and look for any paper jams in this area.
Good luck
Jan 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub 162 photocopier paper jam problem
Sep 02, 2008 | Office Equipment & Supplies
212 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
