Question about Brother MFC-7840W Multifunction Laser Printer MFC7840W
What is wep key - Brother MFC-7840W Multifunction Laser Printer MFC7840W
Posted by tlee4_mn1 on
J.D. Browning
  • Brother Master
  • 2,760 Answers
Wep = Wired Equivalent Privacy this is basically a password to keep your wireless system secure
Posted on Jan 23, 2016
How can I find my WEP key?
Check on the bottom of your router or wifi router or on the side its your security key to hook up the device to your other devices.
A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:examples below
  • 1A648C9FE2
  • 99D767BAC38EA23B0C0176D15
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
Aug 10, 2012 | HP Computers & Internet
What is a wep key and how do i find it
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi Routers and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other.
Dec 27, 2011 | Computers & Internet
We are trying to sign on to our home network but the WEP key, after entering, keeps saying settings are invalid. What exactly is the WEP key? What do we need to do?
Are you trying to connect to your internet connection for wireless? If it is, the WEP key is the password that you set up for your wireless device so that devices that can see the your wireless network will be able to connect by entering the right WEP key. If you didnt change the WEP key of your modem or router, then the default WEP key will be found at the back of your device, but if you had changed it before then, that's the WEP key that you need to enter.
Sep 05, 2011 | Nintendo DSi Black Console
I need to know what the wep key is
Jun 10, 2011 | Linksys WRT120N Router
What is the wep key
A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F. Some examples of WEP keys are:
  • 1A648C9FE2
WEP keys are chosen by a network administrator. WEP keys are set on Wi-Fi routers, adapters and other wireless network devices. Matching WEP keys must be set on each device for them to communicate with each other. The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
Feb 15, 2011 | Linksys E3000 Wireless Router
Informed WEP key is a 10 digit number. could 231408&sid nos. & characters be my WEP key?
A WEP key is a security code used on some Wi-Fi networks.A WEP key is a sequence of hexadecimal digits. These digits include the numbers 0-9 and the letters A-F.
WEP keys are chosen by a network administrator, it would have been provided by the Internet Service providers, Hence it can't be as what you stated.
Oct 30, 2010 | Computers & Internet
What is a wep key, and where will i find it, for setting up xbox 360 thanks
WEP stands for Wireless Encryption Protocol and it is the wireless key for your router.
You will need to find the WEP key in your router's administration page and then enter it on your xbox under the system settings then network settings.
Dec 25, 2009 | Video Game Consoles & Games
I need wep key westell model 327w
Unfortunately, no one could not provide you any WEP key. WEP is a key that you set to your router so that no one could connect to your wireless network. As an owner of the network, you should know what your network key was.
If you forgot your WEP key, you need to reset the router to factory default, configure it and set a new WEP key.
That is the only way. Thank you!
Nov 02, 2009 | Westell Wirespeed VersaLink...
How do i reset my wep key or locate my old one
To locate your wep key.log into the router under wireless security there you should see it.If not you can use a paper clip to reset it.The hole is at the back next to the ports.
Good luck
Sep 28, 2009 | NetGear WGT624 Wireless Router
Brother MFC-7840W Multifunction Laser Printer MFC7840W Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
