It also will not play any CD/DVD that I put in it but will play music and videos that were on my computer prior to upgrading to Windows 10. If I try to burn I get this message: Cannot continue with the burning process, because no burning device was detected. Install a burning device and restart burner name to burn a disc. I have changed nothing except upgrading to Windows 10. The devices worked before upgrading. Can you tell me why it will not work now and how to fix it? I'm a novice and my brother, the computer whiz, got married and moved away. Thanks, JD Morris.
SOURCE: CD Burner Does Not Work
Try a different make of disc, if same uninstal and re-install burning software. If you think the cd rom maybe has a driver problem, check this link to and try solution No.2 to try and solve. http://www.fixya.com/support/t126369-e_drive_wont_start_up_any_product
SOURCE: atapi pioneer dvd-rom 115
you need to install a dvd player in orfer to play dvd. you can download the software total video player, and many others
SOURCE: using windows dvd maker vista
two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
SOURCE: Hp pavillion a810N xp.. Can't burn a CD?
the computer should have came with system restore disks the software should be in there otherwise you can look on download.com and maybe they have some software that can help you out.
SOURCE: dvd/cd rom drive cant read any disc
cd/dvd drives are cheep, I would suggest in device manager uninstall device driver and re-install them with scan for new hardware. If thats not working goto ebay and get a cd/rw dvd reader try to pay a max of $20.00 you should find many in that price range.. and when re-installing make sure the jumper is set to the same as the one you currently have..
Hi Joel Morris, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
please tell us what software you are trying to burn the disc with and if you are using a "factory" pc (ie. a dell pc or a compaq) if yes what is it's model number ? so we can tailor advice for you specifically
