Question about Crate Music
Has hardly any volume but everything else works fine.
Hi, you hadnt mentioned how long you've had the amp, or how new it is, so I'm going to assume it's new to you. The Crate VTX200 has 3 channels, each with its own volume level. Let's check the simple things first:
1. Check to make sure you're adjusting the same volume knob volume knob to the same channel. The active channel will be lit with a green light.
2. Check the cables from the "Speaker Out" jacks on the amp (if you are using them). Are they plugged in all the way, or are they damaged?
3. Are you playing through a preset that you may have accidentally made "low", and may not be aware of or are stuck in it?
If none of these answers helps, there might be a problem with the input buffer in the circuit or possibly within the damping circuit of the speakers. I'd advise having the amp serviced to confirm an internal electrical problem also. If you don't have a manual for the amp, one can be found here:
http://www.manualguru.com/crate-amplifiers/vtx200/users-manual
Posted on Jan 30, 2016
Aug 16, 2015 | Crate Music
Mar 27, 2014 | Crate Music
Mar 24, 2014 | Crate Music
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Aug 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Jul 29, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Mar 08, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Dec 14, 2009 | Crate Music
Jun 19, 2009 | Crate Music
Feb 16, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Sep 08, 2019 | Crate Music
Jul 18, 2018 | Crate Music
73 people viewed this question
