SOURCE: canon photocopier user manual
Contact Copier Care PROSPECT SA. Phone 08 82695711
Yes the copier is VERY VERY old.
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
SOURCE: forgot ID password of my ir2020 canon photocopier
first, you need to be an administrator with an administration id and pass to change any id and pass
please call canon Technical support, they can help you without damage.
SOURCE: how to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
SOURCE: e000000-0000 on canon ir2200 photocopier how to
this is tadesse E000is the main thermiistor (TH1) has poor contact or
an open circuit. the termal switch (TP1) has an open circuit.the main
/sub heater has an open circuit .the main power supply PCB is faulty.
the DC controller PCB is faulty .you can clear starting service mode 1)
press the user mode key *
2) press '2' and '8' on the keypad at the same time
3)press the user mode key * on the contrl panel
(copier, fuunction,clear,ERR
