So if I type the letter l and then type the letter h it is simply typing over the letter l. it only does it when the letter l is typed.
SOURCE: IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
SOURCE: IBM Personal Wheelwriter 2
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
DickyO
SOURCE: My IBM Selectric II types the wrong letters.
Sounds like the cable might have slipped off the pulley, with the cover off, check all cables to the carriage assy. You need a tool like a spring hook to gently slide the cable back on to the pulley.
SOURCE: needing bold typing on IBM Wheelwriter 6 Series II
To get bold you need a WW 10, 15, 1000, 1500 or any of the later models have this faeture.
DickyO
SOURCE: MY IBM SELECTRIC II TYPES THE WRONG LETTERS.
Not good. You probably turned the element while removing it and if you are lucky had it come off one of the pulleys, but more likely it came off the wheel under the element. Then you will need a tech.
DickyO
