Question about Rowenta Vacuums
Could you please advise me where I can a replacement battery for a "Rowenta Air Force" cordless vacumn cleaner. The battery is RS RH 5273 18.0 volt
Posted by Gordon Elliott on
Jerry Kramer
  • Rowenta Master
  • 3,904 Answers
I am sure Batteries Plus will have what you need.
Posted on Jan 21, 2016
I have only had my Dyson V6 for about 2.5 years. It now doesn’t charge. Can there be a reason for this as it only gets used about once a fortnight? Thanks.
Battery packs on Dyson V6 models are usually good for about 3-4 years. If yours is not holding a charge, I would first suggest replacing the battery pack. Also, I do not see any reason as to why not using it often would affect the battery life since these models are made to be able to stay on the charger for long periods of time without damaging the battery itself. If replacing the battery doesn't help, I suggest consulting with a technician. I hope this helps.
Sep 30, 2018 | Dyson Vacuums
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Should a Dyson 45 battery work on a Dyson 44 motor head?
The listings on 3rd party batteries like at NewEgg (
HQRP Battery for Dyson DC31 DC34 DC35 DC44 DC45 DC56 Series plus HQRP... ), Ebay (
NEW DYSON DC44 DC45 VACUUM Battery Type 2000Mah CORDLESS DC34 DC35 4402B ), and others lump the battery for the DC44 and DC45 together, so you're probably fine.
You may want to take the battery to a Batteries Plus or such - sometimes a battery will show voltage just fine, but choke once there's a load on it. They have the gear to tell (same as with car batteries)
Good Luck
Apr 11, 2015 | Dyson Vacuums
I have a new Dyson DC44. It has a screw rather than a push button to remove the battery. I bought a spare battery. When I unscrew/loosen the screw, the screw won't come out and the battery won't pull
Hi Mike, it's Jack at Dyson.
Our cordless vacuums including DC44 Animal now include a fixed battery which is not designed to be removable in everyday use. As DC44 offers a runtime of up to 20 minutes of high, constant suction, we've found Dyson owners don't usually need an additional battery to complete cleaning tasks.
The battery is removable if it ever needs to be replaced, but we would advise against attempting to swap the batteries in normal use as the machine isn't designed to be used in this way.
For further advice I'd encourage you to contact our Support team directly - you can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 22, 2013 | Dyson DC44 Animal Digital Slim Cordless...
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
180 people viewed this question
Top Rowenta Vacuums Experts
Andrew Taylor
Andrew Taylor
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
