I have mine programmed but I'm not she its scanning all of them
Easier to Read Pro 651 652 106 197 WS1040 1065 PSR 500 600 Digital Scanner... (enhanced instructions)
PSREdit500 Configuration Editor for the PSR 500 PSR 600 PRO 106 and PRO... (paid software) You'll need a data cable to use this or other software. I use this for my Pro-106.
SOURCE: i have a pro 96 scanner that i just cant seem to program. how can i do it?
Go to Don Starr software link at:
http://starrsoft.com/software/win96/default.asp
The best $30 you will spend to make the Pro 96 sing for you.
Also use:
http://www.radioreference.com/
This site has all you need to get going and a direct download of frequencies and talk groups for trunked systems...
Cheers,,,Tom M sends
SOURCE: Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
SOURCE: HOPKINSVILLE KY. POLICE DEPT. CHANGED TO A
Unfortuantly the pro-82 is not a trunked scanner, it's only a vhf/uhf scanner and cannot pickup trunked systems. You need to replace it with atleast a pro-95 to pick up trunked systems. If you need your manual for the pro-82 follow this link.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
SOURCE: Programming Motorola type II system
The BR330T is an analog only scanner. Prince William County's system is 800 MHz digital, which your scanner cannot receive. You can receive the fire department simulcast of "5A" (their fire dispatch channel) on 154.325 in analog mode.
