GE Advantium 120 Convection/Microwave Oven Logo
Question about GE Advantium 120 Convection/Microwave Oven
Display light is gone. Oven works but cannot see any display? So cannot use help
Posted by lonnie haseltine on
Microwave gone dead 2nd time
thats easy - ITS WARRANTY - take it back -
Microwave will not heat. Display pad lights up, all features work, on that work, turntable moves, but no heat...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
I have a Smeg FME24X 900 Watts Microwave Oven, and has stopped working, no power but occasionaly the display lights for a fraction of a second, any ideas? Have tried replacing fuse in plug but still only...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
heatman101
Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
GE zmc1095 microwave beeps and indicates "HOT" in the display
If it stops heating it needs a new magnetron. our oven is less than 2 years old and has gone thru 2 magnetrons so far. Hoping to get some help from GE.
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Top GE Microwave Ovens Experts
vince
Marvin
Marvin
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
