Question about Patton PQH307UM Electric Utility Heater
Can I buy a heating element for this heater? - Patton PQH307UM Electric Utility Heater
Posted by Willie Patterson on
  • Virgil Watts Dec 16, 2018
    My advice is don't buy any product without the service information.& part numbers. If you can't fix it yourself at least you have it for the serviceman. Some parts don't have part numbers on them.
Claude Kayser
    Top Expert:
  • 9,098 Answers
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Posted on Jan 19, 2016
Part number for standard heating element for eco smart 11.3kw?
Go to ecosmartus.com
Click products tab at top of page
Click on your model number
Click on replacement parts tab
Buy part from ecosmart
Or remove element from water heater and look to see if threads are standard water heater element threads... then look at volts and watts printed on end of each element... buy ordinary element if it will work.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2015 | Element Water Heaters
What is the part # for a Rheem 308 71 model heating element needed?
Any generic element will work.
Match wattage with current element.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#parts
Rheem wants folks to buy parts from them... so Rheem tries to convince people that Rheem electric water heaters require special parts.
This is not true... ordinary generic parts will function fine on Rheem.
Gene
Oct 14, 2014 | Water Heaters
My heater is not working at all only my power supply light is on
unplug the heater. remove the screws holding the control panel, pull the control out from the body of the heater enough to get the probes of an ohmmeter onto the connections that lead to the heating element. the ohmmeter should read less than 100 ohms. if the ohmmeter reads infinite ohms (open circuit), the heating element or the connections to it ate bad. if the heating element is bad, cheaper to buy a new heater. if the heating element is okay, repair connections or control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 31, 2013 | Honeywell HZ519 Baseboard Heater
I need part # for heating element 81V80D
Buy generic element from hardware store:
Copy following link to identify element and see installation tips.
80 gallon, non-simultaneous electric heaters usually have 4500 watt elements
Avoid promotion of 'lifetime' or 'resistorized' or 'all copper' elements as a waste of your money, ... but might be beneficial by adding surge to the economy.
Apr 02, 2013 | Rheem 81VP6S/430126 Water Heater
Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
On my Impact Heat Gun IMHG 2000 the heater element failed. Can I buy a new heater element?
Buy a new heat gun at Harbor Freight. They are much cheaper than the new element would be if you were able to find one.
Aug 03, 2011 | Heating & Cooling
How do I add oil to help heater warm better??
they are a sealed heater you can't add oil to get more heat, if you can must be a new type i haven't seen, but if not hot enough throw away and buy a heater that works they work on the principal that an element heats the oil and runds on an internal thermostat to control temperature of oil, your element may be starting to deteriate the same as hot water you only notice with hot water as it starts to not heat the water as much and you feel this in a shower or bath but you won't notice the same in oil heater it won't heat as it has and it may also be the thermostat, inside heater i wouldn't even bother trying to repair waste of time and money i would buy a proper working heater prefrably one that could be fixed to go better after its starts to deteriate a lttle
Nov 29, 2010 | Lakewood 2727 Heater
Where can i buy a replacement heating element for my lay z spa heater
I got a new heating element off eBay, it was just a double straight line one like the one already in the metal tube (in the pump). It fit, i wired it up and it works!!
May 20, 2010 | NRS Infratech Single Element 61-1/4 inch...
Caldera spas hot tub Olympic model blows circuit breaker trying to heat up
Remove all pwoer and then gain access to the heater probe. Read each probe from the center connector treminal to the metal base with an Ohm meter. There should be no reading. If you have low reistance the probe is internally shorted and will need replaced. It is a common failure for a heat probe. If the probe is bad when you do buy a replacement buy the "Coated" element. The extra $15.00 is well worth the investment in the overall lifetime of heating element service.
Replacement elements can be found here
Thanks for using FixYa.
Kelly
Mar 22, 2010 | Pool & Spa
Need heat element for fasco wall mounted bathroom heater, the element is M shaped
try to found a local manufacture for heating elements, like http://rezistoterm.xhost.ro/ , give them the old heat element and the power of the bathroom heater (ex: 3000W and 220v, or 2000W and 110V) and they wil macke new oane and much chep like an original one.
Feb 14, 2010 | Fasco Heating & Cooling
Patton PQH307UM Electric Utility Heater Logo
513 people viewed this question
Top Patton Heating & Cooling Experts
Marvin
Marvin
Paul Carew
ray gallant
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
