Question about Apple iPod nano 3rd Generation
Why don't buttons work?
I'm able to move the menu bar up and down. I just can't select anything.
Posted by Austin Brixius on
I've lost restore down in Word. How can I get it back?
if you are referring to microsoft word
Microsoft Word is one of the most widely used text editors in the business world today.
Using Word, you occasionally experience glitches like missing Menu items.
You open Word and while preparing your document realize the Menu item you want to use has magically disappeared.
You can restore it easily.
There are ways to restore lost Menu items in Microsoft Word.
Check your Menu to confirm the button you are looking for is really missing.
Microsoft Word is intuitive and continually adjusts to show the options you choose most often.
Click the double arrow near the bottom of the Menu items to reveal the hidden options.
Click the Menu item you are looking for.
Use that Menu item often and Word will place it in your Menu for easy access.
Replace the missing Menu item in Microsoft Word. Click Tools - Customize.
Select the Commands tab.
Click Rearrange Commands.
Add the Menu item you lost in Microsoft Word.
Select the Menu bar at the top.
Use the drop down menu to select File. Open Controls.
Highlight the Menu item under the File menu and click the Add button.
Select File under Categories. Open Commands and select desired button.
Click Ok.
Word will reveal a preview of the File menu including your changes.
Select the desired Menu item.
Click Add.
To adjust the position of the Menu item you added.
Click Move Up or Move Down.
Continue to adjust them until you achieve your desired results.
Click Close to close the window.
Click File, Exit to close Microsoft Word.
hope this helps
Oct 14, 2012 | ASUS P5PE-VM Motherboard
The remote has new batteries and is able to power the Wii on and off. The A button works to move from the safety screen to the Menu. The home button takes you to the home menu. The problem is there is no...
You can either purchase a new brand-name or third party Wii Sensor Bar for 9-20 dollars at various online shopping websites, such as Amazon and eBay, or you can go into your local gaming shop (e.g. Gamestop) and purchase a wired or wireless Wii Sensor Bar.
Sep 21, 2011 | Nintendo Wii Console
Cannot change the language to english it is currently japanise
looks like you have to reset it
to do that slide the hold button to hold and then back
then press and hold the menu and the center buttons at the same time for about 7-8 seconds until the apple logo shows on screen
if after resetting, the language is still Japaneses, then do this
Scroll down to the last menu option but don't select it.
Scroll up one menu item. This should be Settings.
Press the Center (Select) button. This takes you to the Settings menu.
Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
Scroll up to the third menu item from the bottom one. This should be Language.
Press the Center button to select Language.
Select your preferred language from the list.
Jul 18, 2011 | Audio Players & Recorders
Hi, need to know how to print only black & white documents on my new Canon MG6150. Tried changing printer preferences to greyscale, but that didn't work
go to print in the menu bar
click properties button
click features tab
Select Print in Graycale
click drop down under Print in Graycale and select Black Ink Only
Click Ok to affirm changes
click ok to print
Feb 19, 2011 | Cannon Office Equipment & Supplies
I delted toolbars to make my window bigger and now I can't get the toolbars back. I don't have anything to click on - just the windows that are open.
The Firefox "menu bar" includes dropdown menus for various tasks (including "File", "Edit", etc.). If the menu bar does not display, press the "Alt" key (if you are using Windows). That will restore the menu bar temporarily. To restore it permanently, go to the menu bar and select:
View > Toolbars > Menu bar
The Firefox "navigation toolbar" includes the "back", "forward", "reload" buttons, and the address bar (where you type a web address). If the navigation bar does not display, go to the menu bar and select:
View > Toolbars > Navigation toolbar
The Firefox "bookmarks toolbar" displays frequently used bookmarks. If the bookmark toolbar does not display, go to the menu bar and select:
View > Toolbars > Bookmarks toolbar
See screenshot:
Jan 28, 2011 | Mozilla Firefox
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
LANGUAGE IS NOT ENGLISH
It was your setting. You can change it to english.
For sansa clip:
1. From main menu, select settings (picture with 4 bars)
2. Use up/down button to find " FM...", the language option is right about FM..., select it and use up / down button to find English.
3. Press home button to come back main menu
Good luck
For sansa clip plus:
1. the same as about.
2. Getting into Settings, you have 4 options (Music, Audiobook, Radio, and System Settings). Languages with letters (a, b, c, ....), you can see "Radio...." option, move the selection bar down 1 - it is System Settings. If Languages without letters a, b, c, ...., you have to get in to each option, at each option you move the selection bar down or up to find letters " USB...." , it means you are inside System Settings, from USB, press down button 6 times, and select it (language option), scroll up/ down to select English.
3. The same
Good luck
Feb 04, 2010 | SanDisk Sansa Clip MP3 Player
I just bought a rockband 2 for XBox 360 all the
You mean the strum bar, right? In order to test this, strum up and down in any menu in the game. If your selection moves up and down then it's working, if it doesn't move at all, then you have a broken guitar. You'll need to contact EA for an RMA. Information on that was included in the packaging of your game.
Dec 30, 2009 | MTV Games Rock Band Bundle for Xbox 360
Change the language from chinese to english
Ok, First scroll up until u see like and equalizer. It'll have 4 bars and 2 bars are up, and 2 are down. click the right button. then Move down 4, then click the right button. And from there your able to get the languages.
Jun 24, 2008 | SanDisk Sansa e260 MP3 Player
How do I adjust my monitor?
1)Press Menu button once to get the Main Screen Of Menu
2) Select the option which you need to modify (Ex. Brighness)
3) Now again press Menu button to get into that sub menu (Brightness)
Jun 01, 2008 | Computers & Internet
Apple iPod nano 3rd Generation Logo
69 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
