Question about Siemens Dishwashers
Milky water when rinsing in dishwasher & gritty covering on dishes
I have been having some problems with my Siemens dishwasher. The dishes have been coming out with a gritty film on them. I have been trying to work out what the problem is, and topping up rinse aid, salt and increasing the salt setting to make sure it is not a hardness issue. No success. I have days when the dishes come out fine and others when they do not. I noticed yesterday when it was on a rinse cycle that the rinse water in the bottom of the dishwasher, and I assume being used to rinse the dishes, was a milky colour and I guess this is what is drying onto the dishes. I also noticed that the bottom spray arm was not rotating. I am not sure if there was much spray coming out of it, but I did see it this morning on the first cleaning rinse part of the cycle rotating and spraying as it looks like it should. Any thoughts most welcome. Jus
Posted by Justin Guest on
Andrew Taylor
    Top Expert:
  • Siemens Master
  • 31,554 Answers
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Posted on Jan 19, 2016
Testimonial: "Andrew. Thanks for this. I am not sure why the wash water and rinse water are mixing, sounds like some residual water being left behind in the dishwasher and not being pumped out- though it is completely dry this morning after a wash (and the post are sparkly...), so there is not a problem with the pump it seems. I sat in front of it this morning opening and closing the door while it was on the wash part of the cycle and noticed the bottom spray arm was not spinning, nor much water coming out. I wonder if it is a blocked pipe somewhere that is not getting water into the spray arm (via a pipe leading to the arm) as I often take them off and clean the arms themselves. I will try to see if the water is coming from the top to the bottom spray arm, as the top spray arm is spraying well. It is not scaled up- we have run several descaling attempts."
  • Justin Guest
    Justin Guest Jan 20, 2016
    Sorry, put the comment in the testimonial box. Apologies...
  • Andrew Taylor
    Andrew Taylor Jan 20, 2016
    The wash arms should spin freely when spun with the hand. If they do, then there may indeed be a blockage in the supply pump, the pipes or maybe the impeller in the pump has broken vanes?
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
When wash dishes, there is gritty like food on all the dishes and we use liquid for cleaning dishes. I rinse all dishes before I place in unit.....what is the problem?
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.The water temperature should be minimum of 140 degree Fahrenheit.
Also check the filter in your dishwasher for any debris accumulation.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 09, 2010 | Maytag Dishwashers
Not sure what model but Frigidaire Dishwasher- the dishes are cloudy and gritty. The water gets hot, the cycle seems to be running normally, but even if I put clean dishes in, they come out cloudy and...
The problem is hard water leaving those spots. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 20, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Lately my dishes in the diswasher (and silverware) come out cloud
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 27, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Siemens buillt in dishwasher
do you pre rinse the dishes before puting in dw?if so stop and dont use as much detergant
Jun 03, 2010 | Siemens 24 in. SE64A630GB Built-In...
THE DISHWASHER LEAVES A FILM ON ALL MY DISHES - ALMOST SEEMS GRITTY - I HAVE SOAP AND RINSE AGENT WOULD IT BE TOO GETTING TO HOT
Apr 29, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our dishes are milky colored and not appear to be clean!
Hard water, or not rinsing well. I use
"Lemi shine" in one of the soap holders.
Also make sure you have plenty of jet dry in
the rinse aid holder. These two things make
my dishes sparkle. I live in Arizona, and
our water is horrible it eats away at everything.
Mar 03, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How to access and clean the filter around the food grider
problem is hard water actually. go to www.dishwasherfilter.com. they have a new product out for this exact problem. works great and is very affordable.
Dec 21, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
123 people viewed this question
Top Siemens Dishwashers Experts
luvduct-tape
Level 1 Expert
Mike
Paul Bade
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
