Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Why does it brew weak coffee?
Coffee is weak, pucks are no longer created, all I see in the trash is ground coffee beans.
Posted by Yvon Bertrand on
Michiel Franke
    New Friend:
    Problem Solver:
  • 5 Answers
Hi, maybe you can adjust the grinder setting in the beans container. setting it to closer to zero/0 will make a finer grind. Make sure to only adjust the grinder setting while the grinder is running! (otherwise it will ruin the mechanism).
Posted on Feb 13, 2016
Stefano Andreani
  • 69 Answers
Can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Posted on Jan 24, 2016
"less coffee" message comes up. Why?
It seems that for whatever reason not enough grounds are being produced to make the correct size puck of coffee for brewing. You need to investigate what quantity of grounds is being produced and find a way to increase it.
Oct 24, 2014 | DeLonghi Coffee Makers & Espresso Machines
Xp9000 does not in form me that it has run out of beans, any help please , thanks
They only know that the beans is empty when it comes to compressing the grounds into a puck just before brewing. If the brew unit has nothing in the chamber to compress then it assumes you are out of beans.. Remove and thoroughly clean the brew unit and make sure grounds are exiting the grinder when the grinder is running.
Oct 19, 2014 | Krups Super Automatic XP 9000 Espresso...
Syntia swims in water in dreger drawer
Syntia is not set to "3 beans" amount or beans used are too large to create enough grounds to make a full 9 grams for a good puck .
The finger guard does not allow enough beans to grind in the timing of the software , common problem.... until the finger guard openings are made bigger or ... the software is re-programmed
Mar 05, 2014 | Saeco Syntia Espresso Machine & Coffee...
Bosch benvenuto b30 had for years and loved. Now when use beans the coffee/espresso is too watery and pucks are like sludge after. Works good when use preground coffee .
You have accidentally turned down the brew strength selector, on front of unit just above "clean" and "descale" buttons. Dial it the the maximum. Will grind longer, make more grounds, larger puck, stronger coffee. Or this dial is broken/ wire broken etc. u can disassemble per some other posts on here and check wire connections. I did all that then realized someone had just turned it down. So I turned it to maximum strength and problem fixed.
Oct 15, 2013 | Bosch Benvenuto B30 Espresso/Coffee Maker
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
Hi, I have a Miele 4070 that I... Answer Hi, I have a Miele 4070 that I bought 3 months ago. It made great coffee for the first two months... (More) Hi, I have a Miele 4070 that I bought 3 months ago. It...
d-hound same problem spoke to tech re 4070 they say it is just gring amount and beans and grind they are wrong made great coffee 30 days now **** water please call Randy 484-695-2450 or [email protected]
Jan 05, 2010 | Coffee Makers & Espresso Machines
Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Jun 04, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
450 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
