Question about HP Computers & Internet
How do I fix the internal speaker sound of HP 3380 MT?
The sound driver is okay sound can be heard when ear jack is plugged in, but when it is plugged out the internal speaker will not respond. I changed another good speaker but no sound. how do I fix this please?
Posted by Nnamdi Mbamobi on
I need help please anyone i have no sound coming from my hp stream 11-d009tu i have uninstalled and re installed my auido drivers and still nothing
step by step inch by inch
BT sound ok
HDMI sound ok
main sounds dead. at internal and at ext. 3.5mm line out jack dead.
that means BIOS has that chip off , so go to BIOS and turn it on
if it is on, the get the driver from HP
you have yet told the full service tag data here.
so i cant even go to hp for you and ask them can I.
so why dont you go to hp and ask them
and they will ask you for the service tag, or fails.
Jan 02, 2018 | HP Computers & Internet
Turn off the phone speaker when ear phones are connected?
that is a function of the ear phone jack some aftermarket buds do not plug far enough in to disconnect sound going to internal speaker tray another set
Jan 02, 2015 | Samsung Galaxy S 4G Cell Phone
Speaker is off
Most of these combo units do not have a speaker ON or OFF setting but look anyway.
If the set has a earphone jack that may be the problem--see if works with earphone plugged in.
The socket the jack goes into can get flaky as when jack is inserted it turns the sound OFF.
Also put your ear right to the speaker to see if anything at all is heard--the speaker could be bad--but check the above first.
SD TECH
May 27, 2012 | JVC TV-13142 13 in. TV/VCR Combo
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Sep 15, 2011 | IBM ThinkPad Soundcard
My hp laptops volume sounds really distorted im not sure why?
The first thing to check is to ensure you have the most updated drivers for your computer and the audio section. If that is okay, then it may be that the speakers are busted. If you have a set of headphones, you can plug them in and if the sound is okay, then the problem is probably your speakers.
Nov 29, 2010 | Computers & Internet
I got a cobra 29classic cb, little hours. i have
Set the squelch and knob to full counter-clockwise position. Turn the volume up to the 1/2 way point. Disconnect the external speaker plug from the jack. Disconnect any PA speaker plug from jack. Static / voices should be heard from internal speaker. If not disconnect the mic. Static / voices should be heard. If not, tune a different channel, sound should be heard. if not, look for indication of the radio stuck in transmit mode. If in transmit, there will be no sound until you can stop transmitting (hopefully while connected to a 50 ohm dummy load or suitable antenna - otherwise the final transistors may be blown). Reconnect accessories to determine problem component.
Mar 12, 2010 | Radio Communications
Is my sound card fried?
hmm ,,,r u not geting sound ,,well try download the sound drivers ,,you can download the sound drivers from this website sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
Jan 13, 2009 | Computers & Internet
Headphone jack not working
i just had it solved once for my frend. . wat to do is uninstall everything realted to yur sound hardware .. and get the latest updates ... from ..their site ... and install it .. it will work .. before .. doin this just try ....
1 conect the headphone
2 open the mixer .. in that there will selection of device. .. from that select headphone if it is available. ..
thnx
Nov 04, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
64 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
