New battery could be faulty or alternator not working.
If nothing happens when you turn the key,to check battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested.If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
the link below explains a complete diagnosis,
press the helpful button
Engine Won Crank or Start
When it's to start it all my lights,heat and radio turn on. And the battery is literally two days old from Canadian tire..
New batteries can be defective, it happens more then people realize
Checked the battery and it's good to go..also,when I try to turn my car over not a sound happens,not a click or tick or anything...but all my lights,radio,heat etc come on
