Refrigerators Logo
m
matt helms Posted on Jan 19, 2016
Does the plastic vent near floor just snap off?
1996 vent system troubles
Blend doors not working properly.There may be a round diaphram type thing on the floor near the floor venting.Some of them have small vacume lines on them.They may have split or came off.
2answers
No heat out vents/floor vents
usually the problem is a small vacuum leak for the hvac system. start by checking the small plastic hoses near the a/c drier (the black cylindrical thing) at rear of engine compartment on the passenger side. typically it is a black plastic hose about 1/8 inch thick. you car repair by using a short piece of vacuum hose as a splice to put the two pieces together, make sure the hose fits snuggly on the plastic hose. hope this helps
1helpful
I am trying to find the accuater valve to see if it is stuck or not. the a/c is only blowing air out of my defrost and floor vents. it will not switch over to the vents. can you help me with a diagram of...
LOOK FOR A VACUUM LEAK UNDER THE HOOD NEAR THE A.C DRYER THERE IS A BLACK PLASTIC VACUUM LINE THAT GOES INSIDE THE CAB ,IT SUPPLIES ENGINE VACUUM TO THE A/C CONTROLL. USUALLY FIND THIS LINE BROKEN OR DAMAGED BY RATS
HOPE THIS HELPS
13helpful
2answers
Heater only blowing out defrost vents
Open your hood and find a "T" connector right near the battery. Follow the line down below the battery (you will have to get under the Jeep). You will see that the line plugs into a 3 to 4 inch section of 3/16" tubing that is plugged onto a black in color, plastic box. Use a razor knife and trim off about 1/2" of this 3/16" tubing as it commonly cracks where it fits on the nipple of the black plastic box. The vacuum cannot build pressure properly with these cracks in this tubing, and therefore cause the selector door to malfunction when operating heat and a/c. It is a quick and easy five minute fix.
97 Chevy Tahoe dash vents not working
ck for vaccum leaks at engine comparment small plastic lines
12helpful
2answers
2002 Toyota Camry LE has no heat to the floor regardless of the setting
I temporarily fixed this issue on an 02 Camry last night . It has to do with the little plastic arm that opend the door to the floor vents. Get in driver's side and look under the dash toward the center on the cabin air box. There is a small white plastic bit with a cheanell in it and it i supposed to mate to white plastic bit with a little metal knob in the end. The plastic chanell wears out and allows the metal know to come free, hence the door to the floor vents wont open . It's quote obvious once you get down there and loot at it . Simply put the two pieces back together and its all good, creative use of a very small zip tie will fix this one for good.
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
