SOURCE: Door lock light flashing
Shame to say it but yes..
You board behind the control pannel is blown. this is caused by either a faulty door swtich or the motor.. Your model number tells me its most likely the door switch.. The control board will need replacing and the door swtich.
Getting to the board is easy only three screws near the soap draw. make sure you write which wires go where and to getto the door lock undue the door rubber if you needany further advice let me know
i have worked on more the 300 of these machines
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: gw11 fisher & Paykel
Peace
ngfam1 at you service,
It sounds like it may be a faulty lid or door sensor!
A&E Factory service is nation wide and only charges $75 service call in my area!. (NJ)
They are available 24/7 to set appointments!
Bless You,
Please give me a good rating befor e you sign off of fixya.com
SOURCE: washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
SOURCE: Hi!
I've had the same problem. I removed the top lit and found some pressure
transmitter and a pressure switch. I suspect that the pressure
transmitter is use for measuring the waterlevel in the machine. I think
the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few
times on the transmitter. After doing this the machine washes without a
problem since then.
Hope it helps for you.
did you ever figure this out? I am having the same problem Mike
