When I put it on charge it's charging as normal then when I start the red light comes on and it doesn't work???? Please help ASAP Thank you ??
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
SOURCE: Braun Series 7 760cc dead after 2 months
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
Also... I am not responsible for any damages that may occur.
SOURCE: my braun silk epil xelle
Probably a whole bunch muck is inside theyre (science Project ewe), are you sure you want to open it up? ok... there should some screws underneath the plastic covering but you will need to kind of rip that off and reapply some sticky appoxy after.
SOURCE: Broke my Braun Silk Epil Xpressive
Hey , were your able to find any solution for your problem. I opened my epilator and now this wire is not in its place. I dont remember how it used to be :(
SOURCE: My Silk Epil 7 has
My Braun worked fine the last time I used it & would not come on when I tried it today. Worked on it & found it to be jammed with hair. Would not rotate. Scrubbed it with a toothbrush, started digging out the hair, forced it to rotate, scrubbed it some more, & rotated it some more. The more I worked with it the more hair kept coming out. It's rotating fine now. I think I'm going to clean it with my water pik. My Braun is the kind that can be used with water & the top part comes off. Haven't used it yet but I think I have fixed it. Wish I could get it apart to clean it out but the head of the screw is strange & I don't have anything that will turn it.
