Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error says that I have the Scanner lock switch on when I have it off
Posted by Robert Nespoli on
What does E7 mean
  • E7 - Scanner locked error
    1. Turn the scanner off then move the lock switch to the "Unlocked" position. The lock switch is located on the left side of the scanner.
    2. Plug the power for the scanner directly into the wall, not in a surge protector or battery backup
Aug 18, 2014 | Xerox Documate Office Equipment & Supplies
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Error light on and saying scanner error
Hi!
Open the Lid for scanner, check for a switch on the side for Scanner Lock. Try to switch it to unlock position and retry booting up Printer. That should take care of scanner error message.
Hope this helps. Cheers!
Mar 04, 2011 | Epson Stylus CX3200 All-In-One InkJet...
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Close the document cover.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
SCANNER ERROR 12
Not sure if this particular model has a scanner lock/unlock switch for transporting but I would definitely check for the switch either on the side of scanner or underneath the scanner and make sure it 's not in the locked position.
Jan 03, 2011 | HP LaserJet M1005 Printer
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
My 5800 keeps telling me to unlock it when I click scan, but I can't find the lock anywhere.
The 5800 scanner does not have a physical lock switch. DO NOT attempt to open the scanner and unlock the hardware. This could be either a hardware failure or software
Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
Ensure you are using the correct power supply for your scanner. If you are using a power supply that has the incorrect DC output, you will get a scanner locked error message. This flatbed scanners has I believe 100-120V AC input and 12V DC output.
Plug the power directly to the wall, not a UPS battery back-up, power strip or surge protector. Power fluctuations from a UPS battery back-up, power strip or surge protector may be causing this error. If all this fails try reinstalling the scanner driver
Aug 18, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Mar 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Scanner seems stuck and causes error
you can always try to install the printer on a friend's pc as a test of the printer...do you have the install cd? if not try canon's site to download it.
Aug 10, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
