Question about Kodak ESP5 AllInOne InkJet Printer
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Posted by Peggy Matlock on
Claude Kayser
    Top Expert:
  • Kodak Master
  • 9,098 Answers
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Posted on Jan 18, 2016
Printer working but page is blank after printing
try this select all in the page that you want to print then press ctrl +p it will show you a window in the bottom of that window press print selection it most work
Jun 22, 2012 | Kodak ESP Office 2150 All-in-one Printer
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer not printing black ink after replaced ink cartridge. 3802 error
DID you remove the small tape sealed on bottom of cartridge?
also check for dried old ink sploch in cartridge cradle bottom
right click printer use the printer utilities to clean print cartridges and align the cartridges nost printers have utilies or tools to assist
Jun 13, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Printhead Error 3802 I have the Kodak ESP 5 all in one printer. It started printing blank pages a little while ago. Sometimes if I tried to print a couple of times it would eventually come out, so I knew...
3802 Mean Printhead Failuer
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it that again for (5x)
Tell this to kodak support
And tell the troubleshooting steps you did.
Mar 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer prints blank pages. computer screen shows ink in cartridges
screen shows ink but many of the times if the cartridges are dried up it will print blank pages.clean the cartridge head clogging manually and then try.otherwise replace the cartridges.
Dec 07, 2008 | Lexmark Inkjet Z517 Photo Printer
ERROR CODE 3802
This is how I fixed this problem may or may not work for you. I removed the ink!!! Then I removed the ink tray. This is fairly easy if you fell the top of the ink tray you will find a small square that is slightly raised push in on the square while pushing down on the tray this will release the print head. Very carefully clean with 92% alcohol and a q-tip! Don't apply pressure to the print head it will ruin it!!!!!!!
This allow to air dry for at least a 5min. Reinsert then recalibrate the printer! go to printer status and at the very top you will see a rench and hammer icon press it then follow directions!!!!!!
Good luck and god bless
Nov 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP5 AllInOne InkJet Printer Logo
216 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
