Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Will not print. What does error 5200 indicate?
Posted by H. Mad on
Dennis Maeder
    Sergeant:
  • 257 Answers
See: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5200
5200/P08 - Orange and green light blinking 8 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
Posted on Mar 20, 2016
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Canon Printed LBP 5200 Error Code E000
This error indicates fuser error, its not heating up.
Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Error code 5200 on canon pixma MP258
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on if error still persist replace Ink cartridge or print head.
Feb 01, 2011 | Canon PIXMA MP130 All-In-One InkJet...
My print is Canon MX320. I just changed a new ink, but the error 5200 occured. Do you know what happened? Thanks.
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on, if error still persist replace ink cartridge or print head.
Jan 30, 2011 | Canon Office Equipment & Supplies
Erreur 5200
Jan 29, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Error 5200 shows when trying to print. Not listed in the user manual.
I found a few answers http://www.uktsupport.co.uk/canon/bj/s400.htm
error 5200 indicates print head overheating. You might try printing 1/3 of document, pausing for cooling then print second 1/3, pausing for cooling then print final 1/3 as a work around.
Looks like thr repair cost is more than a brand new Multifunction printer/scanner
Aug 09, 2010 | Canon Office Equipment & Supplies
Service error 5200 canon mp240
Sir,
Error 5200 indicated an error with the print head. Try to cleaning all contacts on the print head as well as on the connecting pad. And also the power needs to be restated, so do it and try it again, just take out the USB, the power from the wall outlet and the USB in the printer itself.
Thanks Good Luck
Sep 17, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
