Freezing up at bottom of freezer and then leaks
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
SOURCE: refrigerator freezer leaking
your defrost drain is frozen or has algae blocking it its at the back of the freezer behind the evaporator cover. You can see it without removing the evaporator cover. You might or might not see the drain hole because of the ice now you can sit and poor hot water on it till it thaws then get a thin wire and run down the tube till its clear or sit there with a hair drier and thaw it .But if you don't mind a small investment ill tell you the best way to deal with it .Go to Lowe's or some where like that and buy you a eureka model 350 hand held steamer.Trust me it will be one of the best investments you'll ever make. You will find 1001 uses for it besides this and the steam will not damage your refrigerator and all the attachments make it very useful.remove the evaporator cover and take the steamer and melt the ice under the evaporator where the drain pan is. Then you will see the drain hole.Put the curved tip on the steamer an start clearing the drain hole now when you get it melted enough to where the curved tip makes a seal around the drain hole let the steam build then hold down the trigger till you hear it at the back of the refrigerator and your done put the evaporator cover back on then think of all the other uses for that steamer now I told whirlpool about it they tested it and now have it posted on their web site that will fix it easy. I hope this is good enough for a four box rateing lol
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
SOURCE: Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
