Question about Canon Office Equipment & Supplies
CANON MX922 INK ERROR CODE 1660 - Canon Office Equipment & Supplies
Posted by Mike Grimes on
Robert john
    Sergeant:
  • Canon Expert
  • 175 Answers
There are various reasons liable for this error. If you want to exclude this error then you need to know the causes of Canon Support Code 1660. Some of the common reasons for this error are mentioned here:
1.Incorrect fitting of the ink cartridges.
2. Misplacement of the ink cartridges.
3. Broken or clogged ink cartridges.
4. If the print machine is not available to recognize the ink tank then you may face Canon Support Code 1660
Solutions that Rersolves Canon Support Code 1660 Easily:-
Solution 1. Reinsert the Ink Cartridge - This is a very simple answer to solve your difficulty. By reinstalling the ink cartridge you can succeed this error.
Solution 2. Cleaned and reset the paint cartridges - If the above solution fails to remove this error then clean and reset the ink cartridges to fix this problem.
BLOG for Support- Canon Support Code 1660
CANON MX922 INK ERROR CODE 1660 - printer-support-3-undefined-undefined-0_71.jpg
Posted on Aug 07, 2020
2 Related Answers
Anonymous
SOURCE: My printer won't recognise the new ink cartirdges
i think you need to buy new catridge..
Posted on May 20, 2009
rachelbiilso
Rachel Bilson
  • 45 Answers
Go through the down mentioned solutions to keep yourself away from such troubling error:Canon Printer Error Code 1660
Step 1: First of all, you need to lift the cover of the printer.
Step 2: Next you need to check whether the red lights on the ink cartridges are turned on or not.
Step 3: If a particular ink cartridge miss a Red Light, it means the position of the cartridge is not correct. Adjust its position and securely place it on the respective places.
Step 4: Next make sure that the orange protective cap is removed or not from the bottom of the ink cartridges.
Step 5: Finally press the Resume or the Cancel button to continue your printing process.
Posted on Jan 17, 2020
Canon printer MX922 work ok changed ink cartridge then code C000 Appeared
The reason for that error code is that there is something in the printer mechanism. Since you say that it happened after changing ink cartridge, make sure there is nothing inbetween the cartridge and ink that interferes, but usually that error refers to something in the way of printing. It is possible that some ink got onto the timing strip when changing ink. Clean that strip if it's the case. More solutions on the video I attached. Hope it helps your printer.
Jul 13, 2017 | Canon Office Equipment & Supplies
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Error code b200 on mx922 how do i fix?
The Canon Printer Error Code B200 indicates a faulty print head. A print head is a part that distributes the ink from the cartridges over the paper, indicating it's one of the most important parts of the entire printer.
Method to Fix the Canon Printer Error Code B200:-
1. Unplug your printer and leave it disconnected for at least 30 minutes.
2. Open the door of your printer and the print head should move so you have access to it.
3. Remove old ink.
Canon Printer Error Code B200 has tried Canon printer users quite often. But, the good point is that there is a method that you can follow for managing and fixing this error. A sincere guide for troubleshooting can improve the user's fix the Error Code B200.
Just follow the steps which are mention on the blog to fix the Canon Printer Error Code B200. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
Dec 21, 2016 | Canon Pixma MX922
Color photos are really off color.
Hi George!
Are using Genuine Canon Ink & Paper?
Here are some links to your printer troubleshooting videos etc.
Canon Support Drivers PIXMA MX922
Jun 30, 2015 | Canon Pixma MX922
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
Canon PIXMA MX920 error code C000
After market units do not send the proper signal as factory cartridges so put the AfterMarket ReMan back in, Un-Plug the unit for 3 minutes . plug it back in and maybe the computer will accept the reman, just will not show "quantity".
Oct 03, 2014 | Canon Pixma MX922
What is code 1683
Hi
I believe code 1683 means 'ink out'. To keep using the printer, either replace the empty ink tank, or to keep printing, press & hold STOP button for 6 seconds or until the error clears. The printer will then work, but you'll still have to replace/refill the ink tank soon.
good luck
Sep 18, 2014 | Canon Pixma MX922
Take a hammer to it yet?...Just kidding Just to ask a question are you using genuine ink for the canon or an off brand?
Feb 11, 2009 | Canon PIXMA iP1600 Printer
677 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
