Northwestern Bell NWB-62800-1 Logo
How do return back to the original message to incoming callers?
How can I get the original message to incoming callers back?
1helpful
Access caller ID ??
View Received Calls on your LG 800G Original Post Date:02/18/2011
  1. From the main screen, press the "Menu" icon.
  2. Press the "Recent Calls" icon.
  3. The "All Logs" tab will appear selected. Press the "Incoming Logs" tab to see the received calls.
  4. Press the call you would like to view to see the call's details.
  5. To return to the main screen, press the red END key.
Kind Regards,
Mike
Mapvps.com
1helpful
Can get answer machine to record callers message after you receive an incoming call
Uniden Customer Phone Number Shortest Wait Best Support
  • Phone Number
    800-620-7531
  • Talk to a Human
    Press 1, then 3, then 5. For the Marine products
  • Useful tools &
    numbers to call
    Compare all options
  • Call Time
    Average Wait: 46 mins - Mon-Fri, 8am-5pm
  • Did this phone number work? Yes No Update this, please
    Help force companies to improve customer service. How
How do you change the incoming message anew caller
on the system you use the vm msg button and your password, you also need to know which numbers your messages greetings, hold, holiday are set at then that is the msg you change.
vmmsg
*# number changed
password
number you are changing
1helpful
Hi i have lost my user guide for my telstra 8200 phone & want to know how to answer a second call while you talking on line 1
To answer an incoming call whilst you are on the phone:
Press and hold the "2" button. Your first caller is put on hold and you can talk to your second caller.
To revert back to the original caller, press and hold the "2" button again.
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Using Conference on Meridian NT4X44
You can use Feature 3 to start a conference call. You would have to hang up the intercom call to return to your original call.
Caller ID
if you are putting 1 then the area code , just put in the area then the number and nt the 1 digit this should help
2answers
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
Top Northwestern Bell Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
