Question about Neff Refrigerators
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Seems to run normally for a while then it sounds like the compressor is starting and then it stops suddenly causing a sudden vibration to whole fridge freezer. Seems to keep trying to start up so repeats. The freezer is struggling to get cold enough consistently. Fridge is maintaining temperature more but at times light is flashing
Posted by Lindsay Willis on
  • Lindsay Willis
    Lindsay Willis Jan 17, 2016
    Model is K8524X4GB/02
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Posted on Jan 17, 2016
Suddenly stopped getting cold.both fans are turning
take the back off of the machine to expose the compressor- if it is hot, but you dont feel the vibration of it running, you will need a new start relay. If the compressor is running, but there is no cooling, you will likely be shopping for a new fridge. Start Device 8201786
May 16, 2016 | Refrigerators
Model gss25lgmb ww
If the compressor is not making any noise and a fridge is worm it means that the compressor is not working. It could be a faulty compressor or a control unit. If it is a compressor, it is not that simple to replace it yourself, unless you have a proper equipment. Because the unit has to be evacuated and recharged with a refrigerant after replacement.
If it is a control unit, it can be replaced, but I would leave it up to a pro to check it out and fix it, if it is worse.
Jan 29, 2014 | GE Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
Hi, was wondering if you could help. I have an Electrolux fridge Model ER6632I that has suddenly stopped cooling. This fridge is approx 8 yrs old. I opened up to the rear of fridge and found that...
Seems that the compressor has some fault within the unit as it takes in more current under pressure. Sometimes it can be due to fault within the compressor, failure of the valve , O-rings. Now shut down the fridge for about 6 hours and then plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. , if RPM of motor is low check capacitor.
Please check this link for tips :
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 25, 2011 | Refrigerators
A loud vibrating sound
Bad compressor, if the compressor is going bad or the bolts that hold the compressor in place are loose. Check to make sure the bolts are tight. If not check the compressor with your hand and see how much it vibrates.
Jan 02, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrigerator suddenly stopped cooling
either the contactor on the compressor isnt engaging or unit is low on refrigerant(when compressor starts you should hear a snap,or click sound) that is the contactor on the compressor
Jul 20, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer dying first, fridge failing...
Is the compressor running. also check to see if the fan next to compressor is running. They should both run at same time..is the compressor fan running and compressor not? Could be the compressor start relay. Next, is there frost buildup on inside back wall of freezer? If so u may have a defrost control out or defrost heater or defrost terminating thermostat out. Greg
Jun 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Top mount fridge stopped refrigerating, maybe compressor?
It could be a bad compressor or the Start Relay that is bad, an easy way tell if the compressor is bad or not. If the compressor is hot to the touch it's probably the Start relay is bad, but with the Fridgeidare they have had some compressor issues. Good luck
Apr 25, 2009 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
670 people viewed this question
Top Neff Refrigerators Experts
Vernon Taylor
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
