Trying to check all batteries and also using the charger plug in the screen lights up and says eject and then I go to open and eject the cassatte does not work.
Sir
watch carefully at the mechanical portion if the pinch roller at the cassette running path is loose or slipped out.
look the capstan motor shaft whether there any clogged dirt or it has become tight, use CRC spry to clean it. loose the head drum with finger.remember do not touch the scanning chip on the drum.
SOURCE: Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
SOURCE: Samsung Vp-D103i V-light get on.
Do you have the correct adapter?It sounds like you have the wrong one.
SOURCE: door to open and close to insert blank tape
i will take it to see if the camcorder itself is bad. thanks for your help
SOURCE: Canon mv940 camrecorder won't power up even with charged battery
My friend went back to England and got it sorted there
Thanks
a
