Question about Refrigerators
Fan starts but won't keep running - Refrigerators
Posted by bob thompson on
Brad Goodale
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Possible shunted wiring not connecting properly.
Posted on Jan 17, 2016
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
Car won't start after starting it with coolant temp sensor disconnected
Try a boost first before taking things apart,sound like low voltage.
Now about the fans.Sometimes it's easier (if the fans will work with voltage applied) just to install a relay and fire it off the switched power wire at the A/C compressor.Use this relay supply to voltage to the fans when the compressor runs.Want fans when not using A/C?Run a "in rad hose" temp switch and run that wire to the same relay to run fans when temp rises.Think after market hot rod stuff and keep it easy and simple,
Apr 10, 2017 | Cars & Trucks
My engine fan keeps running and won't shut off.
try to clean the fuse box and keep it dry from humidity
Sep 13, 2017 | 2001 BMW 325Ci
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Climate control panel won't lite up & the fan keeps running
I would start looking for a used panel. Use a online used part search engine is my suggestion.
Oct 04, 2012 | 1996 Buick Park Avenue
Condensor Fan won't stay running
Check capacitor if its good its the motor
Aug 30, 2012 | Gibson Heating & Cooling
Radiator fan continues to run. Fan won't shut off when engine is turned off.
Its supposed to keep running even with the car turned off if the car is still to warm, they work off a sensor,, now if it keeps running way to long,, the sensor is bad,, ( if you have to pull the fuse to make it quit after a while,, then check the relay , and then the sensor )
Sep 02, 2011 | 1995 Honda Accord
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
