A magnet fell out. I have no idea where or how, or what direction the magnet should be put back in. I can't find any schematics or diagrams close ups of the magnet. I believe my external and internal screens do not work because of this. The phone works perfect I can ring someone or answer a call, but you can't see anything on the screens. Please help. Please give me ideas on how I can fix it. I believe it is the magnet is not in correct place now.
Yes, it is likely that it is the switch directly underneath the magnet - it may be possible to bypass it, but not a good idea. You can order a switch direct from Woodway 1800WOODWAY
Hello sir; on the door there have two pieces magnet when you close the door it will stick on the metal on the machine check it and find out these two magnet is there/
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Use a good strong magnet from the outside while holding it upside down. Move the magnet around the shaft as if going through a maze that you can't see- untill it finds the exit path out! Take an old hard drive apart and use the magnets they have-they're very powerful.
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
