Hello John;
My name is Peter. I am a retired field service refrigeration technician.
First, I would recommend Samsung or LG to someone I did not like. 60% of my service calls were for these units.
You have a solenoid valve for both your ice maker and one for your water dispenser in the lower back bottom corner of your unit.
So, you either have:
1.) A plugged water valve that is not providing 65 PSI water pressure to close the water dispenser valve.
2.) The spool in the solenoid valve is worn or dirty and is not closing fast enough.
Water supply valves will wear. and the rubber seating will block the water supply pressure.
It is only going to get worse over time.
