no problem
you can get fuel lines from e bay that are generic and fit just about any unit
if yours has 2 lines you get the lines as a duel lines system including the rubber grommet for the tank
it will have either a walbro or zama carby and those workshop manual are available as pdf versions
Chinese carbies are knock of those makes so the manuals are applicable
if it under 100 cc then run the 14" bar but if over run the longer bar
siting unused for a period of time , will give you starting problems as the diaphragms dry out and will not work properly
Who makes it --any one guess it there is no other identification available
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video: How to start BlueMax Chainsaw 45CC
A search for Skil here:
Beg for manuals thread (ArboristSite) (free to join) http://www.arboristsite.com/showthread.php?t=72322
Nets a few hits. One for a 1616. Post your need Someone probably has what you seek.
Lou
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
