Question about Dirt Devil Vacuums
I have a Dirt Devil easy light cyclonic vac went through punch list everything is good no suction either end where is my problem
L Pfaff
    Top Expert:
  • Dirt Devil Master
  • 11,573 Answers
Vacuum motor propeller damaged, clogged with deb re or loose fan,
motor worn out.
Posted on Jan 15, 2016
My dirt devil cyclonic upright has suction on bottom but not in cleaning wand
Take the hose off where it goes in to the vacuum and see if there is something lodged in the opening where the hose fits in to.
Mar 18, 2018 | Dirt Devil Vacuums
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
Dirt devil jaguar pet vacuum - no power goes to vacuum
I've literally disassembled the ENTIRE vacuum. I got it for a dollar at the local goodwill with the intent on converting it into a dust collector for my mini workshop. As others have said. The suction is abysmal. I don't think it could beat a dust vac. And that's with just the motor hooked to dirt collector. No brush, no belt, no carpet adjusting. Just a motor, dirt collector and hose. Zero suction. Removed the hose, zero suction. Remove the dirt collector, solid suction. Dunno if the dirt collector is missing a part, but I doubt that based on other replies. I'm guessing all the holes in the red tube of top chamber are the issue. But I can't easily access it. I think I may end up cutting it open to try plugging some holes or some other modifications. But this vac is garbage in its original configuration
May 22, 2011 | Dirt Devil Vacuums
I have cleaned the canister, the filter, everything....and yet the dual blades won't turn and there is barely any suction. HELP?
the suction part must be a clog in between the suction port into the unit check that and if they dont turn maybe belt broke or something is stuck
Feb 15, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Our Dirt Devil D2 bottom has no suction
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
Mar 13, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
My dirt devil reaction is spitting out dirt everywhere. how do i fix this?
Sound like you have an obstruction in the suction path. check the foot (bottom) check for suction at the hose for blockage. the blockage is where you lose suction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 10, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Aug 23, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
My dirt devil vacuum cleaner is not working
Please specify whether the vacuum motor does not turn on when you flip the switch or it simply does not have suction.
Aug 05, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Dirt Devil Reaction Dual Cyclonic- M110000, "cyclones" not spinni
If the filters have been washed and installed back in instantly there wont be any suction. Check the top filters have been cleaned thoroughly and also check inspection tubes/hose and dust channels to check for a clog. Also check the sole plate / bottom of where the beater bar as there may be a clog somewhere.
Jan 15, 2009 | Dirt Devil M110000 Bagless Upright...
Vacuums Logo
96 people viewed this question
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
