Hello, this is Albert with Crucial Vacuum,
If you are looking for the operating manual for the EPIC 6500 Model 1763, it can be found here: Downloadable Owner Manuals for Aerus products.
Click on the "Older Models" drop-down menu and select the "EPIC 6500" model.
Then click the "Download" button just below the same drop-down menu. This should successfully lead you to the Operating Manual for the EPIC 6500 Model 1763.
You can purchase replacement Filter Cartridges for your EPIC 6500: Search results for EPIC 6500 Crucial Vacuum
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
You can download the manual from the Aerus/Electrolux site.
http://www.aerushome.com/Site/Manuals
I hope this isn't too late.
SOURCE: owner's Manual
Apparently there was a split in the company and many repair manuals are under the company Aerus. http://www.aerusonline.com/service/manuals.cfm
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
SOURCE: how do I get to the filter on my epic 6500?
you have a bad controll valve inside the tank. take it to vacuum shop, they can fi the problem and sell you replacement filters. your filter under where the duster brush is stored on top.
SOURCE: I am looking for an owners manual for my Epic
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
