Question about Panasonic KX-T7630 Corded Phone
How do I turn the screen on?
The window is blank
Posted by Georges Pineau on
Blank screen when windows logo apear
motherboard problem. contact laptop technician
Dec 03, 2012 | Computers & Internet
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
My Dell turns on. screen goes blank.
1st problem..... its a dell
2nd problem.....its winnders.
your software is corrupt or there is a hardware conflict.
Its like asking .........My car won't start...why not?
i
Nov 24, 2009 | Dell Dimension 3100 PC Desktop
Screen goes completly blank what ever I am using on my PC. Have to press windows key and retrieve minimizes page to view. Any ideas please
see power settings in control panel.
It must be set on blank screen after 20 mins or something like that.
set it like this
turn off hard disk- never
blanks screen - never
set never with everything
cheers
Jun 22, 2009 | Dell Studio 1737 Laptop
Beeps half-dozen times then shuts down.
try ur windows disk,,put it in and go from there,,reformat if u have to,,or try sytem restore,,
May 17, 2009 | Dell Dimension 3100 PC Desktop
Blank Screen
MS-DOS edit command help edit myfile.txt <press enter>. This would bring up a blank edit screen, as long as the file is saved upon exit this will create the file myfile.txt.
Dec 16, 2007 | CTX Ez Book 700 Notebook
Cant see screen on laptop think its videowave???
Linux and UNIX xset command help The 'reset' flag forces deactivation of screen saver if it is active. The 'blank' flag sets the preference to blank the video (if the hardware can do so)
Read and follow instructions, good luck, please dont for get to Vote/Thank You
Dec 05, 2007 | Gateway 450SX4 Notebook
Panasonic KX-T7630 Corded Phone Logo
97 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
