Brookstone AAXA 50 Lumen HDMI 720p P3 Pico Pocket Projector Logo
A
Anonymous Posted on Jan 15, 2016
Projector turns on, displays Brookstone logo and then turns off. It's not the power; the unit is plugged in.
Jerry Kramer
Level 3:
  • Brookstone Master 3,933 Answers
  • Posted on Jan 15, 2016
Jerry Kramer
Brookstone Master
Level 3:
Answers
3933
Questions
Helped
881362
Points
12076
It is most likely your lamp. If you replace the lamp then you need to reset the lamp timer back to zero or it will keep shutting off on you.
Brookstone HDMI Pocket Projector. Kind sirs, I hope you are good? I have Brookstone HDMI Pocket Projector model 890574 14241BC.
Question edited to correct the written English.
The internal battery has failed and need replacing. They don't like being left for a long time with no power.
https://www.google.com/search?q=Brookstone+HDMI+890574+replacement+battery
What HDMI cable do you use for a brookstone projector
https://www.projectorcentral.com/Brookstone_hdmi_pico_projector_review.htm
Pocket Projector
Mobile includes an HDMI® compatible cable, MHL cable, 5- to 11-pin adapter and AC adapter. To connect to any device without an HDMI® compatible port, you will need an HDMI® compatible adapter or Apple Digital AV adapter (sold separately). Your device: ... Apple® iPad®, iPhone® and iPod touch® devices.
Brookstone Pocket Projector - Good Dog Digital
BROOKSTONE HDMI PROJECTOR 801143 DOES NOT CHARGE
The Brookstone manual claims it will fully charge after 3-5 hours, but it takes much longer then that. Mine does not indicate green light, but it seems it stops blinking red when its fully charged. After that it run on power directly from the ac-adapter.
If you keep it connected to the AC-adapter after it have stopped blinking red (do not disconnect it at all), it will start to run on the adapter and will not turn off. You will feel the AC-adapter gets hot while its running, something it does not while regular charging.
If it still dont stop blinking red after having it connected to power for 3 days, your AC-adapter is probably faulty. This happened to me, and after allot of research I found this replacement from a US seller on ebay (only five dollars included shipping).
http://www.ebay.com/itm/251623019268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck with your projector. It a really cool little thing, but it has some design flaws.
Best regards.
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Projector turns off after 15 or so seconds of startup. The dell logo displays for those 15 or so seconds and roughly 1 second before it turns off, it projects a dialog box. It will shut off much faster if...
The problem you're describing is a classic symptom of a defective fan--some fans simply have + and - power connections. However, other fans have a third, yellow wire, for sending a pulse to the main board to tell it that the fan is indeed running. If the main board doesn't get the signal, it's internal programming instructions perform a shutdown in case of any error condition--protects the unit against excessive heat, current draw, etc. MAKE SURE THE DUST FILTER IS CLEAN! A dirty filter causes the fan to pull harder, increasing current draw, possibly triggering the symptom. The other possibility is a defective power supply causing an over-current condition. Again, the main board senses this and cues a shutdown. You'll need to send the unit out to a repair facility to confirm a diagnosis. Any reputable shop will give you a quote first with an explanation of the problem.
Top Brookstone Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
